Spectronics Corporation has published a new 28-page, full-color catalog on its complete line of Spectroline products for HVAC/R and industrial fluid leak detection.
The catalog contains information about all of the company’s popular leak detection lamps and kits, including the new OPTIMAX 365 true UV LED flashlight and the OPTIMAX 3000 super-high intensity blue LED cordless, rechargeable lamp. Also highlighted are corded UV lamps such as the MAXIMA and the new TRITAN 365 ultra-high intensity, multi-LED, broad-beam UV lamp, which is perfect for identifying leaks in larger AC&R systems. A lamp comparison chart helps users select the right model for their specific application.
Several pages are devoted to the four injection methods used to add Spectroline fluorescent dyes to various size AC&R systems. Hook-up diagrams and technical tips aid in proper injection usage. Detailed charts match the appropriate injection kit and dye cartridge to each lubricant system.
Also included is information about a full range of fluorescent dyes for industrial fluid systems such as oil, fuel, hydraulics and water. A helpful chart explains the precise amount of dye to use with the different host fluids.
For a free copy of the Spectroline catalog, call toll-free 800-274-8888 or download a copy off the company’s Web site at www.spectroline.com.
