Bucket Project for Controlling Leaks
Dave Maki, St. Marys Paper Corp.
Recently a cracked manifold on a piece of production equipment began leaking about 200 liters of hydraulic fluid per day. Getting a new manifold built would take six weeks, meaning we would have to spend nearly $17,000 in replacement fluid. With this in mind, we built what we call "The Green Bucket".
We installed three 3/4 inch coupled ports into the lid of a regular 20 liter plastic pail: one for an air breather, one for a feed, and one for suction. On the suction port we installed a down pipe to one inch from the bottom. On the down pipe we installed a sump float switch. When the pail fills and the float switch trips, a kidney pump sends filtered fluid back to the reservoir. When the pail empties, the switch trips and shuts off the pump.
The Green Bucket is not for all leaks - fluid contamination is a key factor. But in the right application, especially if you are in a pinch, this simple idea could help out your company and our environment.
The Green Bucket
Sump Float Switch
Leaking Manifold
Manifold Leak
The Green Bucket
Share your comments below, or submit your tip for publication here.
