LE Launches Clear Grease Guns to Global Market
Tags: greases
Lubrication Engineers Inc. (LE) was appointed as the global distributor of Clear Grease Guns. These patented clear grease tubes allow users to have 100 percent visual grease identification, therefore avoiding costly grease cross-contamination errors. Grease guns on the market do not allow the grease to be seen meaning that proper grease identification is not possible. The clear grease tubes provide a simple, cost-effective reliability solution to eliminating grease misapplication mistakes. The dedicated Clear Grease Guns Web site provides customers with detailed information on this exciting new reliability offering from LE.
The tubes are available with a variety of assorted color end caps. Color co-ordinate the grease gun tube with the grease points in order to eliminate mishaps, thereby creating multiple forms of positive identification. These anodized end caps are constructed using T6061 aircraft aluminum and colors include: silver, blue, gold, black, red, green and purple. The tubes themselves are made from high-impact, fracture-resistant polycarbonate and use the thread pattern 2.280-16UNS (non-standard).
Clear Grease Tubes fit many existing grease gun models & are available to help modernize existing equipment. Converting existing grease guns is simple and cost-effective for customers. However, LE's Clear Grease Tubes will be available to purchase with a quality pistol grip and a lever style grease gun.
Lever Style Grease Gun
Variable stroke with cast iron head, includes 12-inch whip hose and 5.5-inch steel extension. Maximum pressure of 10,000 psi. It includes a loader nipple and two-year gun warranty; it’s recommended for grease up to NLGI 2.
Pistol Grip Grease Gun
Maximum pressure of 5,000 psi, includes 12-inch whip hose & 4-inch steel extension, multiple loading via cartridge, suction or bulk, comfortable one-hand operation. It includes a two-year gun warranty and is recommended for grease up to NLGI 2.
"The difference that these simple and cost-effective reliability products make is totally clear,”  said Scott Schwindaman, president, Lubrication Engineers Inc. “LE has already received a huge level of global interest for the clear grease tubes from businesses that have realized how accurate grease identification can easily & quickly reduce their maintenance and operating costs – resulting in increased corporate profits. Expensive grease misapplication errors will be a bad memory after converting your preventative maintenance & reliability teams to clear grease guns. If you can't see what is in your grease gun, it's not grease identification it's grease assumption."
Lubrication Engineers Inc. has been a leader in lubricants since 1951. LE manufactures and markets a comprehensive line of heavy-duty, premium-quality lubricants formulated from the highest-quality select base stocks. These lubricants are manufactured under an ISO9001 certified quality system at a state-of-the-art plant in Wichita, Kan. LE products are designed to increase profitability through: longer equipment life, extended service intervals (reduced lubricant consumption), energy reductions, reliability (less downtime), fewer repairs (fewer parts and less labor) as well as less inventory (multi-purpose products).
