InventHelp Creates Tool to Lube Bearings, Pivot Points
Tags: bearing lubrication
InventHelp introduces the "Grease Bug Pump," a lubrication system for construction equipment or other machinery.
The Grease Bug Pump allows an individual to quickly and easily lubricate bearings or pivot points on a piece of equipment. Because it is mounted right onto the equipment, it is easily accessible and easy to use. Ideal for contractors, construction workers or do-it-yourselfers, the Grease Bug Pump will help to save the cost and time of replacing a broken or rusted bearing or pivot point.
The product includes several different-sized tubing and fittings. To use, an individual centrally mounts the Grease Bug Pump onto the equipment, turns the dial to the correct fitting, and then is able to easily pump the grease into the bearing through the tube. The Grease Bug Pump uses standard three-ounce grease tubes that can be purchased at most automotive supply stores or bulk grease that is refilled directly into the reservoir.
