Safely extending oil drain intervals by using fluid analysis to monitor oil condition and engine wear has always been a significant means for reducing a maintenance department’s consumable costs. But in today’s economic environment, it is becoming even more critical to achieve optimal drain intervals and, at the same time, minimize engine damage.
Advanced oil formulations have allowed the industry to make great strides in extending drains. The CI-4 and CI-4 Plus oils used in diesel engines manufactured prior to 2007 had a significant impact. Although many felt this progress would be jeopardized by the CJ-4 oils that were later introduced with a lower starting TBN, better CJ-4 additive technology actually enabled many fleets to increase drain intervals even further.
While fluid analysis is the best way to safely determine an optimal drain interval, the appropriate testing should be done by a reputable laboratory that uses reliable testing methods and produces quality results you can trust. Laboratories that are ISO 17025 accredited are required to prove the accuracy of their results on an on-going basis or risk losing their accreditation.
Safely extending diesel engine drain intervals requires the following tests:
Elemental Analysis
Wear metals
Contaminant metals
Additive metals
Fuel Dilution % by Gas Chromatography
Soot % by FTIR (Infrared Analysis)
Viscosity @ 100° C (ASTM D-445)
Water by Crackle
TBN ASTM D-4739
Oxidation/Nitration by FTIR (Infrared Analysis)
In the past, standard practices for determining optimal drain intervals using fluid analysis have required testing the oil for TBN and TAN. The theory was that when new, an oil’s TBN is high and its TAN is low, and the longer the oil is used, TBN decreases while TAN increases.
The point at which they meet is the optimal time to change the oil. It is important to note that ASTM D-4739 should be used when testing the TBN of used (in-service) oils as opposed to ASTM D-2896, which may be used when testing TBN in new oils. ASTM D-4739 uses a weaker acid for titration than does ASTM D-2896 and, therefore, produces slightly lower TBN results.
Historical test data shows the relationship between TBN and TAN to be quite consistent. TAN just begins to increase when TBN depletion reaches 50 percent. As the TBN drops below 50 percent, TAN begins increasing rapidly. So in reality, TBN depletion can reach about 65 percent before it becomes necessary to change the oil.
Consider a CJ-4 engine oil with a starting TBN of 9.0. TAN will hold steady at around 1.75 to 2.0 until TBN depletes to around 5.5, at which point TAN begins to increase. The two will meet at around 3.15 to 3.5. As a result, most laboratories do not require both a TAN and a TBN to make extended drain recommendations.
The following table represents TBN/TAN test results across a fleet of more than 450 pick-up/delivery trucks. TAN remains fairly steady until the TBN depletes from 12 to about 6. The two meet at between 50 and 65 percent depletion of the TBN. The TAN is significantly higher than the TBN after the TBN has reached 65 percent depletion, which indicates that the oil’s ability to neutralize acids has dropped significantly. The oil should be changed to prevent corrosive engine wear from occurring.
Table 1. Determining Optimal Drain Intervals Using Total Acid Number
Monitoring TBN, Viscosity, Oxidation and Nitration simultaneously and changing both the oil and filters when contamination from dirt, coolant, fuel dilution or soot reaches critical alarm limits is ultimately the best way to determine optimal engine oil drain intervals regardless of the time on the oil.
About Polaris Laboratories LLC
Polaris Laboratories provides complete testing and analysis for oils, fuels, coolants and water-based fluids. The company’s customer base is diverse with a heavy emphasis on the transportation, industrial, oil and gas, off-highway and power generation industries. Our efforts to train and educate our customers on the importance of oil analysis, saves many of them millions of dollars a year in lost production and equipment replacement costs. Headquartered in Indianapolis since 1999, Polaris has grown from a staff of five, to more than 80 employees with laboratories also located in Houston and Salt Lake City. State-of-the-art facilities and instrumentation, highly skilled laboratory technicians and data analysts, and a national team of technical sales and service professionals have positioned Polaris at the forefront of the oil analysis industry. For more information, visit www.polarislabs1.com.
