Lincoln introduced its new Model 5805 Impact Fitting Cleaner as a time-saving alternative to fitting replacement and joint disassembly. Designed to eliminate downtime caused by dried blockages, the Impact Fitting Cleaner clears obstructions by allowing lightweight oil or solvents to enter the clog with a quick burst of pressure. The Model 5805 also cleans bearings and joints of hardened grease so that fresh grease can be applied.
The Impact Fitting Cleaner includes a steel drive cylinder, hardened piston and safety shield. In addition, the Model 5805 comes with a high-pressure hose for hard-to-access fittings, spare drive seals and Lincoln's Model 5852 Coupler.
For more information on Lincoln's Model 5805 Impact Fitting Cleaner, call 314-679-4200, ext. 4410, or visit www.lincolnindustrial.com.
