Lubricant for Food Machinery is Clean, Clear and Non-Tacky
Tags: food grade lubricants, bio-based lubricants
Unique to food and beverage manufacturers is the need for a machinery lubricant that is clean, translucent and approved for incidental food contact, as well as non-tacky for frequent washdown of equipment. Sheerplex food grade – a new multi-purpose premium grease created by Lubrication Engineers Inc. – meets all of these needs and more.
Sheerplex lubricant is NSF H1 registered, Kosher Pareve certified, and cleared for use in USDA-inspected facilities. It is an aluminum complex, NLGI No. 2 grease manufactured with white mineral oils, performance additives and organo-metallic thickeners that are approved for incidental food contact. Its smooth, non-tacky texture ensures a clean and easy process for the frequent washdown of food equipment, and provides for outstanding pumpability in centralized lube systems.
Sheerplex food grade lubricant doesn't contain any pigmentation, so it appears nearly transparent in use - highly desirable for equipment that requires regular visual inspection. In addition, Sheerplex features LE's renowned anti-wear properties, which provide protection for expensive equipment. Its corrosion inhibitors give it an excellent rating on bearing corrosion tests, providing rust protection for equipment that experiences high levels of water contamination. Sheerplex also performs well under mild acid or alkali conditions.
A wide operating temperature range of minus-20 to 400 degrees Fahrenheit means that Sheerplex has great low-temperature mobility for use in the refrigerated areas of food plants as well as exceptional oxidation resistance at the elevated temperatures used in food processing.
Thanks to its odor-neutral, non-pigmented, non-tacky formulation, Sheerplex lubricant is refreshingly pleasant for service and maintenance personnel to use.
"The food industry is one of our most important markets, and our H1 lubricants provide outstanding performance for our food processing customers," said Scott Schwindaman, president, Lubrication Engineers. "We developed Sheerplex grease based on feedback from our customers. It is a great addition to our H1 line. The reliability of food manufacturing equipment continues to improve thanks to the performance of LE's H1 products and the knowledge and experience of our LE lube consultants."
About Lubrication Engineers
A leader in lubricants since 1951, Lubrication Engineers Inc. manufactures and markets premium lubricants formulated from highly refined base oils. These oils, together with LE's proprietary additives, provide unmatched performance in nearly any application operating in normal-to-severe conditions. All Lubrication Engineers lubricants are manufactured in an ISO 9001:2000 certified quality system at LE's state-of-the-art plant in Wichita, Kan., and are available worldwide. With its comprehensive offering of versatile lubricants and related reliability products, LE provides its customers with increased profitability through longer equipment life, extended service intervals, reduction in energy use, fewer repairs and less need for inventory. For more information about Sheerplex grease or any other LE products, or to find the nearest LE independent lubrication consultant, call 800-537-7683 or go to www.le-inc.com.
