Introduction to Lubrication and Oil Analysis Training
Tags: lubrication programs, lubricant sampling, oil analysis
Machinery Lubrication and Oil Analysis Training
Introduction to Machinery Lubrication and Oil Analysis
In this three-day training course, you'll gain skills that you can use right away to reduce downtime and operating costs.
Course Overview| Registration| Certification| Dates and Locations
What You Will Learn:
How Lubrication Affects Machine Reliability
• Financial benefits from achieving lubrication excellence
• Five equipment maintenance strategies, and when each applies
• Important implementation steps to lubrication excellence
• 10 roadblocks to achieving lubrication excellence
Lubrication Fundamentals
• Six important functions of lubricating oils
• How oils and greases are formulated and why it is important
• How friction is generated in lubricated machinery
• The importance of oil film thickness and critical clearances
Understanding Additives, Base Oils and Grease Thickeners
• How lubricant properties irreparably change
• Seven important physical properties of a base oil
• The importance of API’s five base oil categories
• When to select one of the six most commonly used synthetic base oils
• How to use temperature to determine the right base oil for your machine
• How to select grease thickeners for your application
Lubricant Performance Properties
• 14 key additives that enhance lubricant performance
• Understanding viscosity grades, measurement, and reporting
• Why Viscosity Index is important and how it improves your work
• Lubricant performance tests and reporting – what you need to know
• How water contamination generates other contaminants
• How to control and eliminate aeration problems
Food-grade and Environmentally-friendly Lubricants
• Important USDA requirements and government regulations for food-grade lubricants
• What you need to know about food-grade additives, base oils and grease thickeners
• Advantages and disadvantages of food-grade lubricants
Lubricating Grease Application Methods
• Seven tips for avoiding incompatible grease mixtures
• Advantages and disadvantages of centralized lubrication systems
• Best practices for greasing motor bearings
• How to calculate greasing intervals and quantity
• Best practices for ultrasonic/sonic-based greasing
• Important tips for working with your motor rebuild shop
Lubricating Oil Application Methods
• Overview of oil lubrication methods and devices
• How to use oil mist and other automatic lubrication methods
• Using pressure spray methods for gearboxes
• Best practices for the maintenance of grease guns and fittings
• Overview of single-point direct lubrication systems
Selecting Lubricants
• Journal and rolling-element bearings
• Open and closed gears
• Gas engine and gas compressors
• Air compressors
• Hydraulic fluids
• Steam and gas turbines
• Process pumps
• Multipurpose grease
• Oil mist lubricants
Lubricant Contamination Control
• Building reliability through contamination control
• Seven most destructive contaminants and how to control them
• Three steps to proactive maintenance
• Understanding the ISO Solid Contaminant Code
• 10 ways to maximize filter cart usage
Oil Drains, Flushing, and Reservoir Management
• How to optimize and extend oil change intervals
• Interval vs. condition-based oil change
• How to monitor lubricant consumption
• Best practices for oil changes
• How and when to perform a flush
• Selecting appropriate cleaning and flushing procedures
Storage, Handling, and Managing Lubricants
• How to set up a world-class lube room
• How to optimize lubricant selection/procurement
• How to implement a lubricant consolidation program and select suppliers
• Best practices for inspecting/testing new lubricants
• Used lubricant storage, handling, and disposal best practices
Design and Inspect for Lube Excellence
• World-class strategies for accessorizing equipment for lubrication excellence
• Seven critical accessories for inspection and sampling
• Seven critical accessories for contamination control prevention
• Eight essential lubrication accessories
• What your breather is telling you about your machine
Used Oil Analysis Fundamentals
• What oil analysis can tell you
• Types and categories of oil analysis
• Applications for oil analysis
• Overview of oil analysis tests
Oil Sampling – The Very Best Practices
• 11 elements of a successful oil analysis program
• How clean should sample bottles be?
• How to find the best sampling locations
• Sampling valves and hardware recommendations
• A quick method for optimizing sampling intervals
• An oil sampling technique that ruins trending
• The importance of primary and secondary sampling points
• How to properly sample circulating systems
• Safe, effective high-pressure sampling from hydraulic systems
• Best practices for sampling splash-, collar-, and ring-lubricated systems
Essential Field Inspections
• 12 questions your filter will answer about your machine
• Which visual inspections can provide big results
• Used filter inspections
• Quick tips for using scent, sound, and touch to inspect lubricants
Questions? Call 800-597-5460 or email registrations@noria.com.
