CRC Thread Lubricant Prevents Seizing and Galling
CRC introduces Thread Lubricant, a lithium-based, general-purpose lubricant that prevents seizing and galling caused by high temperatures, heavy loads, vibration and corrosion. Use on aluminum conduit, bolts, bushings, fittings, flanges, nuts, pipes, plugs and screws. Its fine particle sizing makes it an excellent choice for closely fitted parts that need lubrication.
CRC Thread Lubricant will not compromise the integrity of soft metals so it’s a good choice for use on soft metal applications. It facilitates fast and easy disassembly of parts which helps reduce costly down time. This unique formula has a smooth texture, low odor and is non-flammable. It is safe for use on both ferrous and non-ferrous metals. CRC Thread Lubricant is available in an 8-ounce Brush-Top bottle (part #SL35925).
CRC Industries manufactures a complete line of industrial specialty chemicals including: cleaners, degreasers, lubricants, corrosion inhibitors and paints. The company markets its products through electrical and industrial distributors nationwide. CRC Industries is certified to ISO 9001:2000 standards.
