2011 Chevrolet Cruze Engines Will Use Eco-friendly Cartridge Oil Filter
General Motors
The 2011 Chevrolet Cruze will make proper oil filter disposal and recycling easier. The Ecotec 1.4-liter turbo and 1.8-liter four-cylinder engines will use a cartridge style oil filter which is easier to recycle and service compared to the conventional steel canister-style oil filters.
Recycling canister style filters requires that the metal housing and other elements, like the rubber seal, be cut away or separated, whereas the compact cartridge style is made of only paper and plastic. Because of this, proper disposal of the oil filter is easier for recycling centers.
Another benefit of the cartridge-style filter is that it can be changed easily and is virtually drip free from the top of the vehicle. This lessens the chance of oil dripping to the ground or driveway and possibly making its way into the water system when performing oil changes.
The housing for the cartridge-style filter is part of the engine and reused for the life of the engine. It never needs replacing. The housing also has a screw-on replaceable cap that eliminates the conventional canister-to-engine mating surface that is a potential source of leaks.
To find out more on how and where to properly recycle oil filters, go to www.filtercouncil.org
