The Omnilube family of lubricants from Ultrachem Inc. is a complete line of premium-quality food-grade synthetic oils and greases for incidental food contact that are specially designed for reduced lubrication intervals, longer equipment life, less downtime and reduced maintenance costs. Omnilube lubricants are available for compressor, hydraulic, chain, gear and multi-purpose applications and are well-suited for all food, beverage, pharmaceutical and related industries.
Omnilube food-grade products meet all of the requirements of the USDA and FDA H-1 regulations, 21 CFR 178.3570, and conform to the requirements of NSF. They are also approved by the Orthodox Union for Kosher use.
Ultrachem's Omnilube fluids are formulated with excellent anti-wear protection and oxidative stability, qualities that have been shown to surpass other food-grade products on the market and outperform many non-food-grade lubricants in food processing applications. "With the Omnilube line of premium food-grade synthetics and white oils," said Bob Whiting, president of Ultrachem, "performance is no longer sacrificed when converting to food-grade products."
Omnilube fluids are formulated from the highest-quality polyalphaolefin (PAO), polyalkylene glycol (PAG), ester and mineral base oils, depending on application. Ultrachem also offers food-grade grease and multipurpose oil in convenient 12-ounce aerosol spray cans.
About Ultrachem
Established in 1965, Ultrachem is one of the oldest specialty synthetic lubricant compounders and has become a leading supplier to the OEM and industrial maintenance markets. With its headquarters and manufacturing facilities in Delaware, Ultrachem offers a wide range of products including food grade lubricants, impregnating oils and gels, high-pressure compression lubricants and gas compression lubricants. Ultrachem is a member of the Independent Lubricant Manufacturers Association (ILMA).
