ASTM Wear and Erosion Committee to Visit UF Tribology Laboratory
Tags: industrial lubricants
ASTM Committee G02 on Wear and Erosion is including a field trip in the plans for its December 8-9 meeting in Jacksonville, Fla. Committee members will be visiting the Tribology Laboratory in the mechanical engineering department at the University of Florida in Gainesville.
The Tribology Laboratory is actively involved in a wide variety of tribological research and tribology education projects. The laboratory primarily conducts studies in solid lubrication (investigating the friction and wear of materials). Research goals at the laboratory are to engineer and design materials that:
  • Have improved wear resistance, which enables components made of these materials to last longer;
  • Have a reduced friction coefficient, which saves energy, improves efficiency and generally results in smoother operation; and
  • Can survive extreme environments where conventional fluid lubricants are not effective – temperatures above 350 degrees Celsius and below minus-40 Celsius, vacuum environments and many others.
In addition, the laboratory is conducting research on nanofilled composite materials. These materials are made by reinforcing various thermoplastics with various nanometer-sized metal oxide and carbon fillers.
For more information on the G02 meeting and the Tribology Laboratory tour, contact Kathleen McClung, ASTM International (Phone: 610-832-9717; kmcclung@astm.org).
ASTM International welcomes and encourages participation in the development of its standards. For more information on becoming an ASTM member, visit www.astm.org/JOIN.
ASTM International is one of the largest international standards development and delivery systems in the world. ASTM International meets the World Trade Organization (WTO) principles for the development of international standards: coherence, consensus, development dimension, effectiveness, impartiality, openness, relevance and transparency. ASTM standards are accepted and used in research and development, product testing, quality systems and commercial transactions.
