Simplify Oil Analysis Report Interpretation
Tags: oil analysis
"I just saw a substantial increase in copper on one of my oil analysis reports. How can I determine where this copper came from (cooler core, bearings, worm gears)?"
Trying to effectively interpret oil analysis data without an intimate knowledge of a machine's internal design and operating condition is fraught with danger. Most machines are highly complex, consisting of exotic metallurgy and intricate mechanisms. The numerous frictional and sealing surfaces usually employ varying contact dynamics and loads, all sharing a common lubricant.
Failing to gain knowledge about these many internal machine details as a reference base for use in interpreting oil analysis data may lead to nothing but wild guesswork and confusion. A good approach is to build a binder with index tabs for each machine type. Include in this binder photocopied pages from the service and operation manuals plus other accumulated information.
The following are examples of data and information to include:
  • Identify types of bearings in use and their metallurgy.
  • Identify input and output shaft speeds/torques.
  • Identify types of gears in use, speeds and loads. Determine gear metal hardness, surface treatments, alloying metals.
  • Locate and identify all other frictional surfaces, such as cams, pistons, bushings, swashplates, etc. Determine metallurgy of surface treatments.
  • Locate and identify coolers, heat exchangers and type of fluids used.
  • Obtain fluid flow circuit diagrams/schematics.
  • Locate and determine the types of seals in use, both external and internal.
  • Identify possible contacts with process chemical types. Obtain MSDS sheets for these chemicals.
  • Record lubricant flow rates, lubricant bulk oil temperatures, bearing drain and inlet temperatures, and oil pressures.
  • Record detailed lubricant specification and compartment capacity.
  • Record filter performance specification and location.
