Lead Particles Predict Bearing Failure
Lana Robin, PdMA Corporation
Tags: wear debris analysis, oil analysis, compressor lubrication
History:
  • R.J. Reynolds Tobacco Company had been performing lubricant condition monitoring on its equipment for 20 years.
  • A few years ago, the Predictive Maintenance Group in the Utilities Division implemented a routine oil analysis program to not only monitor the condition of the lubricant, but also to monitor the condition of its machinery.
  • This program was implemented to detect possible impending problems before a failure occurred. The goals were to increase reliability, minimize unexpected failures and decrease downtime.
Laboratory Lubricant Analysis:
  • A routine oil sample was collected from a reciprocating air compressor and sent to
    a lab for analysis.
  • Spectrometric analysis found an unusually high lead content.
  • The Predictive Maintenance department was immediately notified of the findings and quickly shutdown the system for visual inspection.
Evaluation:
  • The lead contamination found in the oil sample was a direct result of the old and damaged rod bearing breaking apart due to age.
Solution:
  • Replace three bearings.
  • The success of this catch reinforced their belief in regular routine oil analysis.
Impact:
  • Downtime and costs associated with repair were minimal.
  • This catch saved R.J. Reynolds Tobacco Company’s Utilities Division an estimated $50,000 to $75,000 on plant machinery had the corrective action not taken place when it did.
Submitted by Lana Robin, PdMA
