Cambridge Develops New Multi-shear Inline Viscometer
Cambridge Viscosity has developed a new multi-shear inline viscometer that is designed to rapidly deliver accurate rheological information in a small sample process stream.
The new viscometer is available for Newtonian and non-Newtonian fluids, ranging from concentrated suspensions to any type of coating application. Measurements from the controller compare well with those on the same fluids under the same conditions as when using a rheometer. The viscometer should be considered anywhere in-line rheometric knowledge is required.
Easy to clean and maintain, the device performs well throughout the viscosity range of 0.2 to 10,000 centipoise. The VISCOpro 2000 automatically cycles through calibrations at three different force levels to test at low, medium and high shear rates. The system allows users to easily distinguish between Newtonian and Non-Newtonian fluids, and results of the discrete steps are reported within 10 to 15 minutes, depending on the viscosity range.
For more information, visit www.cambridgeviscosity.com.
