Spectronics Introduces Starter Leak Detection Kit
Tags: hydraulics, compressor lubrication, gear lubrication, synthetic lubricants
Spectronics Corporation recently introduced a new starter kit designed to pinpoint the exact source of all leaks in hydraulic equipment, compressors, engines, gearboxes, fuel and other synthetic and petroleum-based fluid systems.
The OPK-541 Industrial Leak Detection Kit features the OPTIMAX Jr. blue-light LED flashlight, a compact, high-intensity unit that quickly reveals leaks in small to medium-sized industrial systems. It measures 7¼ inches long and weighs only 5 ounces.
Also included in the kit is an 8-ounce twin-neck bottle of OIL-GLO 44 concentrated fluorescent oil dye, which is compatible with all synthetic and petroleum-based fluids. When a leaking system is scanned with the OPTIMAX Jr. flashlight, the dye glows a bright yellow/green at all leak sources to reveal the precise location of the leak.
Rounding out the kit is an 8-ounce spray bottle of GLO-AWAY dye cleaner, dye treatment tags and fluorescence-enhancing glasses. All components are packed in a rugged carrying case.
For more information, visit www.spectroline.com.
