Schroeder Introduces High-Pressure Filter
Schroeder Industries recently introduced a new top-ported filter that can withstand pressures of up to 6,000 pounds per square inch (psi) at 1 million cycles.
The CTF60 is a 75-gallon-per-minute filter that has three different element sizes to accommodate a wide range of flows. The 5-, 8- and 14-inch elements are offered in Schroeder's Z-Media and high-collapse Z-Media elements for applications requiring the blocked bypass version.
The filter’s compact design makes it ideal for pressure applications that require a space-saving solution.
The housing head is available with optional inlet and outlet female test points for efficient inline sampling (while the system is still in operation). This housing includes a standard 50 psi cracking bypass with dirt alarm indicator port.
For more information, visit www.schroederindustries.com.
