Sprayon Introduces New Food-Grade Low-Temperature Lubricant
Sprayon Products recently introduced the LU 214 food-grade low-temperature lubricant as part of its expanded line of NSF H1-rated food-grade lubricants.
A multi-service lubricant designed for extended service under extremely low-temperature conditions (as low as minus 78 degrees F), the NSF H1-rated lubricant features a blend of pure synthetic oils that are treated with extreme-pressure, corrosion-inhibiting, antioxidant, anti-foam and anti-wear additives.
This unique combination is formulated for maximum equipment protection in extremely low-temperature applications and offers high load capacity. The lubricant also provides rust and corrosion prevention, is non-staining and kosher approved.
For more information, visit FoodGrade.Sprayon.com or Sprayon.com.
