B'laster Unveils New All-purpose Lubricant
The B'laster Corporation recently introduced a new and improved formulation of its all-purpose lubricant.
With more than 1,000 uses and applications, the B'laster All-Purpose Lubricant displaces and repels moisture and is ideal for drying wet or submerged machinery and equipment such as engines, spark plugs, wires, power tools and electric motors. The high-performance formula also reduces friction and noise and helps prevent rust and corrosion.
In addition, the new lubricant can penetrate to free rusted or stuck tools and parts such as nuts and bolts, hinges, valves, dials, chains and locks. It can also be used to rust-proof tools and other metals prone to corrosion.
Based on an independent laboratory test (ASTM D4172), the new formulation outperformed its leading competitor by providing more lubrication.
"Our team was dedicated to specifically improving B'laster All-Purpose Lubricant formula to be the best, and the independent laboratory test results confirm we succeeded," said Randy Pindor, executive vice president of marketing at the B'laster Corporation.
The all-purpose lubricant is available in an 8-ounce aerosol can or a 1-gallon pour can.
Headquartered in Valley View, Ohio, the B'laster Corporation has manufactured penetrants, lubricants, rust inhibitors and a full line of highly concentrated formulas for the automotive, industrial and hardware industries since 1957.
For more information, visit www.blastercorp.com.
