AMSOIL Launches Expanded Coolant, Antifreeze Line
AMSOIL recently launched a new ethylene-glycol antifreeze and engine coolant in two formulations for passenger car/light truck and heavy-duty applications.
The ethylene-glycol antifreeze and engine coolants have been designed with a polyorganic acid formulation and are intended to provide protection against metallic corrosion and erosion pitting, even in extreme temperatures and operating conditions. Both virtually eliminate scaling problems and offer corrosion protection for aluminum, steel, cast iron, copper, brass and solder alloys.
The convenient 50/50 pre-mix is compatible with all other coolants and cooling system materials including hoses, gaskets and plastics.
For those looking for a safer option around children, pets, livestock and the environment, AMSOIL's propylene-glycol antifreeze and engine coolant has been reformulated and offers many of the same benefits as the ethylene-glycol formulation in a low-toxicity, biodegradable option. It is a concentrated formulation that can be mixed to desired ratios.
AMSOIL's antifreeze and engine coolants are formulated to deliver extended service life in gasoline and diesel vehicles of up to 150,000 miles or five years in passenger cars and light trucks, or 600,000 miles or 12,000 operation hours in heavy-duty and off-road applications.
For more information, visit www.amsoil.com.
