Simatec Unveils New Pressure Booster for Automatic Lubricators
Simatec recently introduced a new pressure booster to complement the company's well-established Simalube lubricators. The Impulse can overcome counterpressures of up to 10 bar, making it ideal wherever high pressure is required and for long lubrication lines.
Simply affix the device to the lubrication point, then screw on the lubricator and activate it for the desired dispensing time. The pressure booster requires no additional adjustments. An LED display continuously signals the unit's proper functioning. Once completely empty, the Impulse can be used multiple times if it is equipped with a new lubricator and battery pack.
Together with Simalube lubricators, the pressure booster can help ensure reliable lubrication when faced with high counterpressure and lubrication lines of up to 13 feet. Continuous lubrication impulses of 0.5 milliliters supply the lubrication point with oil or grease at a pressure of up to 10 bar. This action is gentle on the lubricant, as only the dosing volume is placed under pressure.
The Impulse's compact size enables installations in the smallest of spaces and in all positions, even underwater. The device is dustproof, waterproof and suitable for use in a wide range of industries. Equipped with a new battery pack at each refilling, the pressure booster can be used for 10 dispensing cycles or for up to three years.
For more information, visit www.simatec.com.
