TRP recently introduced a new line of lubricants, including engine oils, synthetic transmission oil and synthetic gear oil, for all makes of trucks and buses.
Formulated to guard against wear and corrosion in demanding applications, the four products in the line are intended to protect axle components, transmissions and engines for longer life and smoother operation across a wide range of operating conditions.
For mixed fleets, the TRP Engine Oil (SAE 15W-40 and SAE 10W-30) is made to combat the sludge, varnish and ash deposits that can occur at high operating temperatures while guarding against oxidation, corrosion and rust. It also provides diesel particulate filter (DPF) protection.
The TRP Synthetic Transmission Oil (SAE 50 Synthetic) offers all-climate, year-round protection of heavy-duty manual transmissions. It has a high viscosity index and low pour point for easy shifting in low temperatures.
The TRP Synthetic Gear Oil (SAE 75W-90 Synthetic) is recommended as a rear axle and differential oil in over-the-road and off-road vehicles. Designed for the extreme pressure of heavy-duty applications, the multi-grade lubricant also helps to reduce operating temperatures when compared to conventional gear lubricants.
For more information, visit trpparts.com.
