Macnaught Unveils New Grease Gun
Macnaught Americas recently introduced a new manual grease gun for automotive, fleet, construction, agricultural, mining and industrial applications.
The K32-01 Flexigun incorporates a variable-stroke piston and valve arrangement to facilitate one-handed operation. It is fully serviceable and has a heavy-duty stepped barrel and durable zinc handle for a long service life and improved grip.
The grease gun includes a KY Supergrip three-jaw, high-pressure coupler for a positive connection and utilizes a 12-inch flexible extension to access lubrication points and screw fasteners for simple servicing. The filler bleeder requires no tools to open, while the plunge rod can be locked into the follower for easy bleeding.
The Flexigun’s output pressure ranges from 5,000 to 10,000 pounds per square inch (psi) with an output volume of 0.02 ounces per shot. Compatible with standard 14-ounce grease cartridges, it is also bulk fillable with NLGI No. 2 grease and comes with a 10-year warranty.
Headquartered in Tampa, Florida, Macnaught Americas is a wholly owned subsidiary of Macnaught Pty. Ltd. The company’s offerings include fluid-handling equipment, hose reels and accessories, as well as a complete line of positive-displacement flow meters.
For more information, visit www.macnaughtusa.com.
