Y2K Fluid Power recently announced that it has changed its name to Y2K Filtration to better describe the direction of its products and better suit its customers' needs in the filtration and lubrication industry.
Effective Jan. 1, 2018, the new name will be included on all company mailings, packaging, invoices and promotional materials. While no change in management has occurred, customers can expect the same quality products and service.
Y2K will also add a number of new products in 2018. In addition to the company’s portable filtration units (filter carts, filterpaks, panel units, platform carts, drum toppers, etc.) and water-removal products, Y2K will be expanding its fluid management line with the Power Dispensing Lube Management System, Gravity Feed Dispensing Station and Modular Lube Panel Dispensing Station.
The Power Dispensing Lube Management System is designed to power, recirculate, dispense and fill onboard and external tanks. The Gravity Feed Dispensing Station, which features angled tanks for a true gravity feed, can be used to top off tanks with pre-filtered fluids. The Modular Lube Panel Dispensing Station can handle up to 15 standard stations, including a single station straight from the drum.
For more information, visit www.y2kfiltration.com.
