Macnaught Unveils New Pump System for Oil Applications
Macnaught USA recently introduced a new battery-powered pump system for oil applications. Designed to improve shop efficiency, reduce operator fatigue and eliminate spillage, the BOP20 series is ideal for pumping hydraulic and gear oils from 5-gallon containers. It is intended to replace manual pumping and pour methods.
The 18-volt, 2-amp-hour, lithium-ion battery can deliver up to 40 gallons on a single charge with flow rates up to 1 gallon per minute. The modular pump’s flow nozzle enables one-handed operation with on-demand flow control.
Featuring a safety lockout carry handle, the portable powerhead can be transferred easily across multiple pump stems to reduce setup costs, while the unit’s sealed, wetted parts prevent contamination.
Suitable for lubricants ranging from 0W40 to SAE90, the pump comes with a two-year warranty and is suitable for automotive, truck and bus, marine, construction, mining, aviation and agricultural applications, as well as for plant equipment.
The starter kit includes a pump powerhead, stem with adjustable suction tube, adapter, flow nozzle, 5-foot hose, lithium-ion battery and charger.
Headquartered in Tampa, Florida, Macnaught USA offers a variety of fluid-handling equipment, hose reels and accessories, along with a complete line of industrial-duty, positive-displacement flow meters.
For more information, visit www.macnaughtusa.com.
