Researchers Create Microscale Pumps, Motors, Turbines
The modern-day soldier carries a heavy load. Try to imagine running hard in a desert environment toting some 100 pounds of weapons, body armor, simple medical supplies, food and water, and an array of digital communications and computing devices.
Every fatigue-inducing pound matters, including the 20 pounds of lithium-ion and other batteries that power those digital devices.
A team of researchers at the A. James Clark School of Engineering, led by associate professor Reza Ghodssi and funded by the U.S. Army Research Laboratory and U.S. Army Research Office, has recently succeeded in manufacturing micromachines – tiny pumps, motors and turbines that, integrated in a microscale liquid-fuel power generation system, will significantly reduce a soldier's battery load.
The engineers' advances also hold promise in technologies for health care (micropumps for implantable medical devices) and first responders (bio-chemical sensors).
"For the first time, we have achieved a level of miniaturization for machines like that achieved over the last decades in electronics," said Ghodssi, Herbert Rabin Distinguished Associate Professor of Engineering in the Clark School's Department of Electrical and Computer Engineering and Institute for Systems Research. "Our work shows that it is feasible to manufacture and integrate reliable, robust micromachines that apply tiny pumps, motors, and turbines in ways never before possible."
The central component of their research is the lowly ball bearing, an ancient technology now used in everything from jet engines to dentists' drills -- devices in which parts move at high speeds in close proximity to each other. Ball bearings are simply spheres made of metal, silicon, or other substances that when placed between two surfaces, such as the components of a motor or generator, allow those components to move with less friction and heat than if they were moving in direct contact with each other. The less friction and heat, the faster the components can spin and the more power they can produce.
Using well-known manufacturing techniques similar to those used in the semiconductor industry to make computer chips, the Clark School researchers have successfully miniaturized ball bearing support mechanisms with microballs as wide as a few human hairs and nearly invisible to the naked eye. Using these components, they have built tiny silicon pumps, motors, and turbines demonstrating rotational speeds of up to 87,000 rpm, comparable to the speed of large-scale machinery.
For troops on the battlefield, small-scale combustion generators using such micromachines, and combined with batteries in hybrid technologies, will significantly reduce the soldier's load. States Bruce Geil, acting branch chief for the Power Components Branch of the U.S. Army Research Laboratory, "The Army needs small-scale, liquid-fueled power generators that can provide higher energy, at lighter weight and lower cost, than current fielded power sources. Dr. Ghodssi's team is developing key fuel delivery and electrical generator components to meet our requirements."
Micromachine systems also will help power land or air-based "micro vehicles" (also under development at the Clark School in partnership with government agencies) that will venture into risk-filled environments ahead of soldiers or first responders and send back information. Microgenerators fabricated completely in silicon and supported on microball bearings could power the vehicles' electrical systems without weighing them down.
To create their machines, Ghodssi and his team first had to conquer the science of microscale "tribology" or the friction, wear, and lubrication of tiny rolling components. They then applied this knowledge in building different types of micromachines using conventional manufacturing processes, and finally in integrating these devices into tiny systems that can reliably accomplish a task such as power generation over a reasonable period of time, and not simply burn up.
"Rather than focus on an arbitrary performance specification for micromachines," says Ghodssi, "we focused on feasibility--building pumps and motors that are fast enough to do the jobs required, reliable enough to last, and easy enough to manufacture in the real world. As in the miniaturization of electronics, we expect to achieve successive generations of higher and higher efficiency and refinement in micromachine systems, and to see the creation not only of new defense and medical products, but of entirely new technologies no one has yet imagined."
Related Video
Power MEMS Devices based on Micro Ball Bearing Technology: http://www.ece.umd.edu/MEMS/projects/microball.html
MEMS Sensors and Actuators Lab (MSAL): http://www.ece.umd.edu/MEMS/index.html
US Army Research Laboratory (ARL): http://www.arl.army.mil/www/default.htm
US Army Research Office (ARO): http://www.arl.army.mil/www/default.cfm?Action=29&Page=29
Related Publications
M. McCarthy, C.M. Waits, and R. Ghodssi, "Dynamic Friction and Microturbine Performance Using a Planar-Contact Encapsulated Microball Bearing," Proceedings of the 2008 Solid-State Sensor, Actuator, and Microsystems Workshop, pp. 170-173, Hilton Head Island, SC, June 1-5, 2008.
N. Ghalichechian, A. Modafe, M. Beyaz, and R. Ghodssi, "Design, Fabrication, and Characterization of a Rotary Micromotor Supported on Microball Bearings," Journal of Microelectromechanical Systems (JMEMS), vol. 17, No. 3, pp. 632-642, 2008.
M. I. Beyaz, N. Ghalichechian, and R. Ghodssi, "Toward an Autonomous Electrostatic Micromotor: Integrated Feedback Control," Proceedings of the 21st IEEE International Conference on Micro Electro Mechanical Systems (MEMS 2008), pp. 483-486, Tucson, AZ, USA, January 13-17, 2008.
C. M. Waits, B. Geil, and R. Ghodssi, "Encapsulated Ball Bearings for Rotary Micro Machines," Journal of Micromechanics and Microengineering (JMM), Vol. 17, pp. S224-S229, 2007.
