According to a recent poll of Reliable Plant magazine readers, as much as 60 percent of all plant problems can be attributed directly to "human factors" (Figure 1), specifically a lack of proper procedure (23.78 percent), a lack of training (15.05 percent) or personnel/human error (22.54 percent), which, though not always, is typically due to either a lack of proper documentation (procedure) or a lack of adequate training. What's clear from this is that machines are failing because we either don't know how to maintain them or haven't adequately trained our staff to do so.
So, how does lubrication stack up? In this column, the first of a three-part series, I will look at the basics of lubrication preventive maintenance (PM) procedures. In Part 2, I'll talk about what I call "hybrid PMs", PMs that span multiple technologies. In Part 3, I'll discuss how you should use the information in the PM to maximum effect in the field.
Knowledge Management
Figure 1. How Reliable Plant readers attributed plant problems to various factors.
While we're talking about lubrication PMs, electrical PMs or mechanical inspections, the key is to develop a standard approach to capturing, organizing and delivering information, a field often referred to as knowledge management. Knowledge management is simply information about any business process in a form that can be easily disseminated and used by those who need it. The key here is "easily disseminated and used". Take, for example, a library. Libraries contain tens of thousands of books. But unless each book is carefully catalogued in a system that is user friendly, and the book itself is carefully organized into relevant chapters and a subject index, the information is of little use. The same is true for lubrication knowledge.
As an example, consider the following real-life extracts from lubrication PMs I've reviewed in the past year or so:
Grease the motor bearing - Sure! How much? Which grease should I use? What should I watch for when applying grease?
Check oil level and top off as necessary - But, how do I check the level? Should the machine be running or down when I do my check? What oil should I use?
Sample gearbox - How? Should I crack the drain and insert a drop tube through the breather port, or is there a sample valve located somewhere?
I could go on, but you get the point. When it comes to lubrication, the amount of explicit knowledge or information available to the technician at the point of use is often so limited that, by inference, the technician has no option but to make certain assumptions on the fly. But wait, you say, "Our lube technician has 30 years of experience; he knows what he's doing!"
Let's examine this. So, Joe has been lubing for 30 years? Is it reasonable to expect that Joe has memorized every salient detail (how much, how often, which product or tool to use) for every task? And even if Joe is a true professional with a penchant for memorizing data, what will happen when Joe moves on to that long overdue retirement? Knowledge needs to be captured in a way that leverages Joe's experience but insures that he or his successor is able to execute to a high level of precision and consistency each and every time.
Tacit vs. Explicit KnowledgeExplicit knowledge, on the other hand, is knowledge that has been captured as a procedure, document, training video, etc. In this form, it can be used by others to determine how a specific task should be done.
But wait, you say, "We have lubrication PMs. Our tasks are all documented in lube routes, so we've already captured our lubrication knowledge explicitly." Unless you've documented each pertinent detail (how much, how often, which tool or product), don't fool yourself - a PM cannot and should not be considered explicit unless all gray areas have been eliminated.
Why have few companies taken the time and effort to capture explicit knowledge? Hopefully you all agree that the devil is in the details, not the simple task description. The answer, in my opinion, is that the time and effort to build truly specific lubrication PMs is so daunting, and there always seems to be a bigger fire that needs attention.
The Difference is AccuracyTherefore, ask yourself if you have explicitly captured every detail necessary to lubricate your machines in your lube PMs, or if you are tacitly expecting that Joe will get it right every time. Stay tuned for Part 2, when I'll go into more details of how a lube PM should (and should not) be laid out.
As always, this is my opinion; I'm interested to hear yours.
About the AuthorAs a skilled educator and consultant in the areas of oil analysis and machinery lubrication, Mark Barnes has helped numerous clients develop effective machinery lubrication programs and troubleshoot complex lubrication problems through precision lubrication and oil analysis. As vice president of Noria Reliability Solutions, Mark and his group work on projects in the areas of: plant audits and gap analysis, machinery lubrication and oil analysis program design, lube PM rationalization and redesign, lubricant storage and handling, contamination control system design and lubrication, and mechanical failure investigations. Contact Mark at mbarnes@noria.com.
