Fluidall Introduces Double-Wall Tanks
Fluidall recently expanded its fluid storage and handling line to include double-wall tanks for storing oils, hydraulic fluids, biofuels and more.
The double-wall tanks offer several operational advantages, including extended fluid storage and handling capabilities. The tanks are reusable, compact and economical, and come in 110-, 165-, 275- and 400-gallon capacities.
Each tank can be purchased individually or packaged with an optional leak alarm, fluid level gauge, lockable fill cap with vent, preset or non-preset meter and a Graco pump package with 50-foot reel and air filter regulator.
Engineered to be simpler than dealing with oil drums, the tanks are easy to dispense from and are environmentally safe.
The tanks eliminate the need for additional secondary containment. The steel outer tank acts as the secondary containment and can hold 110 percent of inner poly tank fluids for maximum protection from leaks and spills. The inner tank is made of blow-molded, high-density, seamless polyethylene that is leak-proof and will never corrode.
Certified to UL SU2258 standards and designed to store liquids that are classified as Class II or Class III combustibles, the tanks are also compliant with National Fire Protection Association codes.
For more information, visit www.fluidall.com.
