Klüber Unveils New Spray Lubricant
Tags: industrial lubricants
Klüber Lubrication recently introduced Klüberfood NH1 4-002 Spray, a new water-displacement fluid that can be used as a penetrating oil.
Available in an aerosol spray for convenient application, the lubricant was developed for use around products and packaging materials in the food-processing, cosmetics, pharmaceutical or animal feed industries. The oil can also be utilized to prevent seizures, for example, in the case of a thread and bolt.
Formulated with special oils that are neutral in both odor and taste, the spray is NSF H1 registered and therefore acceptable as a lubricant with incidental food contact for use in and around processing areas.
In addition to food-quality assurance, Klüberfood NH1 4-002 Spray is intended to increase the reliability of production processes. By protecting metal machine surfaces subject to periodic washdowns, the lubricant is able to reduce staining and corrosion through water displacement.
The oil also works to prevent seizure, which can contribute to a reduction in downtime during assembly and disassembly of machine components.
A subsidiary of Freudenberg Chemical Specialties, Klüber Lubrication is a leading manufacturer of specialty lubricants with approximately 2,000 employees in more than 30 countries.
