JTM Products Introduces New Multipurpose Lubricant
JTM Products recently introduced a new multipurpose penetrant/lubricant for industrial applications. The Barracuda Triple Action Lubricant is formulated to penetrate, clean and protect metal. Its unique chemistry is designed to work quickly, attracting it to metal to help break loose corroded bolts, nuts, screws, pipe joints and other industrial parts.
The multipurpose lubricant is also a metal cleaner that can be used to quickly remove grease, grime and rust from metal surfaces without requiring harsh solvents or the odor of similar products.
As a protectant, the lubricant can remove water with a moisture-displacement property that wicks it away from metal surfaces while providing a thin, protective film. Independent laboratory testing has also proven it to be effective as a rust inhibitor on metal surfaces and parts.
The product is ideal for use on stamping blanks and dies for aluminum or steel coil or sheet stock. In addition, it can be employed to rust-proof machine tables, chucks, ways, gears, bushings, tools or implements susceptible to corrosion from high humidity.
The Barracuda Triple Action Lubricant is available in 11-ounce aerosol cans, 1-gallon jugs, 5-gallon pails or 55-gallon drums.
For more information, visit www.jtmproductsinc.net.
