Lubrication Specialties Introduces New Multi-Purpose Lubricant
Lubrication Specialties recently introduced a new multi-purpose spray lubricant to protect metal parts from rust and corrosion.
Never Rust is a 100 percent synthetic lubricant that is formulated to protect any metal surface. It is ideal for use on metal nuts and bolts, cables and chains, metal tools, automotive parts, door hinges, locks and more.
With an operating temperature range of minus 65 degrees F to 300 degrees F, Never Rust can be used in extreme temperatures, in any climate or for any metal application, including automotive, industrial, marine, powersports, agriculture or heavy duty, where long-term protection from rust and corrosion is needed.
Highly resistant to water washout, the lubricant will not dry out, separate or bleed on equipment. It also comes with a 100 percent money-back guarantee.
In corrosion prevention tests using a salt fog chamber (ASTM B-117), the lubricant was found to prevent rust 20 times longer than other brands – a total of 2,700 hours within the salt fog chamber.
In addition to rust prevention, Never Rust can be used to remove labels, tape or stickers and is compatible with most seals, except for ethylene propylene diene monomer (EDPM) rubber.
To apply, shake the 9-ounce aerosol can, hold the spray tip 8 to 10 inches from the metal surface and then spray evenly.
For more information, visit www.hotshotsecret.com.
