Perma-tec Introduces New Automatic Lubrication System
Perma-tec recently introduced a new automatic lubrication system for applications that require only small amounts of lubricant, such as rolling and sliding bearings, chains, spindles, open gears, gear racks, shaft seals and more.
The Perma Flex Plus is designed to immediately discharge lubricant to a lubrication point when the boost function is activated. The selected discharge period can be changed at any time and even turned off for longer machine downtime.
After the desired discharge period has been selected with a rotary switch, the system can be directly installed at the lubrication point. No assembly is required. The unit is immediately ready to use without the need for special tools and can be installed in different positions, including upside down.
The lubrication system’s compact size makes it ideal for hard-to-reach places. The transparent housing allows users to check the filling level at any time and also protects the system against water and dirt.
Able to lubricate points within a temperature range of minus 4 to 131 degrees F (minus 20 to 55 degrees C), the Perma Flex Plus can be used in both moist and dusty environments.
For more information, visit www.perma-tec.com.
