Petro-Canada Lubricants recently launched a new high-performance automatic lubricator to protect equipment in the food manufacturing, general manufacturing, construction, petrochemical and heavy-duty industries.
Grease-N-Go is designed to deliver the right amount of lubricant at the right time for lubrication points in difficult-to-reach areas, such as elevated locations with challenging access, in tight corners, and spaces near equipment that is rotating or subject to high or cold temperatures.
The compact lubricator is universally adaptable and environmentally friendly due to its ability to be refilled and reused. Once installed, it can be left in place to deliver consistently timed lubrication for up to 12 months.
Available for use with Petro-Canada’s Purity FG, Precision and Peerless product lines, Grease-N-Go comes in two sizes (125 and 250 milliliters) and seven different grease products. Both the automatic lubricator’s packaging process and the facility in which it is packaged are also NSF H1 registered for incidental food contact as well as kosher pareve and halal certified.
"The ability of Grease-N-Go to provide the correct amount of our high-performance lubricants at the right time will reduce maintenance costs and unplanned downtime for operators while improving equipment reliability and, above all, operator safety," said Brad Palmer, category manager at Petro-Canada Lubricants.
For more information, visit https://lubricants.petro-canada.com/.
