Rethinking Condition Monitoring Strategies for Today’s Turbine Oils
Greg Livingstone, Fluitec International; Jo Ameye, Fluitec International; Brian Thompson, Fluitec International
Turbine oils have had a fairly boring history over the last century. There are only a few documented cases in scientific literature of problems with turbine oils throughout the 1900s. Similarly, monitoring the life of these fluids was accomplished by employing long-established laboratory tests that provide early warning signals that allow maintenance personnel time to take proactive actions prior to a negative impact on their plant’s operational reliability. If it was only that simple now. Things have changed dramatically over the last couple of decades. Modern turbine oils are formulated differently than their cousins of the recent past, starting with a switch from Group I to Group II (and beyond) basestocks coupled with the incorporation of more complex and effective antioxidant chemistries. Reliance on antiquated analytical techniques has caught many users off guard as these tests are no longer the predictive tool that they once were. The time has come to rethink how we monitor mineral-based turbine oils.
Figure 1. Comparison of the Turbine Oil Environment in Various Gas Turbine Technologies
New Formulation Technologies
Before rethinking turbine oil condition monitoring strategies, it is important to know what has changed in turbine oil formulations as well as the reasons for the changes. If you haven’t guessed by now, most turbine oil formulations on the market and in use today are quite different than those in the recent past. Today’s turbine oils are required to perform more functions in increasingly harsh environments. In some of the more unforgiving scenarios, the same reservoir of fluid simultaneously provides lubrication to the turbine bearings, generator bearings, atomizing air compressors, lift oil system, trip oil system, the generator hydrogen seal system, load gears and a multiplicity of servo valves within the hydraulic circuit.
There have been many driving factors contributing to these oil formulation changes. The three most influential factors on turbine oil formulations have been increasing demands by OEMs, upgraded lubricant refining technologies, and an effort to reformulate for enhanced differentiation and value proposition.
Figure 2. The Influence of Antioxidant Chemistries on RPVOT Values in Group II Basestocks
OEM Influence
Gas turbines are the most demanding application for turbine oils, which also has been the fastest-growing market in the United States for power generation. In 1998, 15 percent of U.S. electrical power was provided by gas turbines. In 2020, gas turbines are projected to provide 39 percent of the nation’s electricity. The efficiency and firing temperature of gas turbines is continually rising as more advanced metallurgies are developed. In general, the stress on the turbine oil also increases with more efficient engines, and most turbine OEMs are demanding increased turbine oil performance. Since the country’s first power generation gas turbine was installed in Oklahoma in 1949, there has been a general consensus that an increase in firing temperature causes an increase in bearing temperature, thus creating increased lubricant stress. Some of the factors that determine how quickly turbine oil degrades are summarized in Figure 1.
The stress on turbine oils, however, may be more complex than just looking at the lubricant’s residence time, high-temperature zones and reservoir temperatures. Figure 1 suggests that the “Class E” system may impart more stress on its turbine oil when compared to the “Class F” system. In reality, turbine oils lubricating Class F units typically degrade faster and have more performance challenges. Additional factors to consider when assessing the stresses on the turbine oil in a system include the environmental conditions of where the unit is located, its duty cycle and the plant’s maintenance practices. In this particular example, Class F units are known to exert further stress on the turbine oil due to a phenomenon known as spark discharge, which occurs in the unit’s main lube oil filters.
Figure 3. Heavy deposits in steam turbines are becoming a more common observation during power plant outages.
Reformulating Turbine Oils to Enhance Value Proposition
Oil manufacturers have brought significantly more refining capacities online to produce higher-refined basestocks, making Group II and III basestocks widely available. Today, most turbine oils formulated in North America are now built with a Group II basestock. The shift from Group I oils to Group II and III oils also has resulted in a significant change in formulation strategies. Certain antioxidants are able to greatly enhance the oxidative stability of Group II and III turbine oils as measured by the rotating pressure vessel oxidation test (ASTM D2272-RPVOT) and turbine oxidation stability test (ASTM D943). As a result, newer turbine oils have much higher oxidation stability values compared to older formulations.
Some oil manufacturers began using RPVOT values as a key selling feature to further differentiate their turbine oils by attempting to correlate the high performance of their turbine oil’s oxidation tests to real-world applications. End-users welcomed differentiating values on oil specification sheets since virtually all of the other specifications are extremely similar. Many turbine oils over the last decade have been selected based solely on RPVOT values.
An example of the influences antioxidants can have on RPVOT values can be seen in Figure 2, based on research by Albemarle Corporation.
In Figure 2, you can see that Amine 2 has a very positive influence on RPVOT values, exceeding 3,500 minutes at a concentration of 0.45 percent by weight. The phenolic antioxidant, however, produced RPVOT results of less than 500 minutes at the same concentration. When the phenol and Amine 2 additive are blended in at equal concentrations (0.225 percent by weight each), the RPVOT value is less than 1,000, demonstrating the potential negative influence that phenols can have on RPVOT values. This is one influential factor why amines have been the antioxidant of choice in many of today’s turbine oil formulations.
Figure 4. This chart shows the degradation trend of traditional turbine oils vs. most modern turbine oils. The selection of condition monitoring technologies becomes more critical with modern turbine oils
It is now accepted in the power generation industry that beyond a certain point, RPVOT values do not directly relate to field performance. This is evident for several reasons:
  • Some of the antioxidants that generate very high RPVOT values also produce high levels of insolubles upon depletion and show direct correlation to the formation of sludge and varnish within the lubricating circuit. To this end, the use of some antioxidant chemistries that contribute to very high RPVOT values has been a contributing cause to the increase in varnish problems in gas and steam turbines. Clearly, there is not a relationship between initial RPVOT values and field performance.
  • RPVOT values can be strongly influenced by the addition of some corrosion inhibitors and metal pacifiers. These additive species can negate the effects of the primary catalyst in the RPVOT test, a copper wire coil, improving the test results and giving a false indication of the fluid’s antioxidant properties. Corrosion inhibitors typically deplete out of turbine oils fairly quickly once put in service as they are polar and designed to provide a protective film to metal surfaces. It is not unusual in some turbine oil formulations to see a sharp drop in RPVOT values during the first year of service as a result of corrosion inhibitor depletion. RPVOT retention is a much stronger indicator of turbine oil performance than initial RPVOT results.
  • The RPVOT test has very low reproducibility for oils above 1,000 minutes and is not a recommended test by ASTM for these formulations. Most commercially available turbine oils now boast initial RPVOT values above, and in some cases well above, 1,000 minutes.
  • The first physical sign of fluid degradation from this experiment was the creation of marginally soluble degradation products, which are known to produce varnish. These are commonly referred to as soft contaminants. Their concentrations were measured directly and trended using the membrane patch colorimetry (MPC) methodology. System varnish remains a high-profile and growing problem in today’s lubricating, hydraulic and insulating systems.
  • The first chemical sign of fluid degradation was observed by trending the depletion of the two primary antioxidants – aromatic amine and hindered phenols. Voltammetry is typically the technique of choice for measuring antioxidants.
  • There are direct correlations between the depletion of specific antioxidants and the formation of soft contaminants.
  • RPVOT testing has as much value as ever in older formulations of turbine oils which are still in service in steam and hydro generating applications.
  • If you have a reservoir with mixed brands or formulations of turbine oils, performing RPVOT testing is recommended to be part of a complete test slate to helping evaluate the condition of the fluid.
New-generation turbine oils degrade differently than traditionally formulated lubricants. The non-linear degradation of most modern turbine oils can be attributed to the specific antioxidant(s) employed, as well as the low natural oxidative resistance characteristics of Group II and Group III basestocks. As a result, the majority of standard oil analysis tests provide little to no warning as to when the lubricant will start to degrade and generate system deposits. Instead of degradation occurring in a linear and predictable fashion, many of these modern lubricants fail rapidly, as depicted in Figure 4.
Figure 5. Graphical Representation of the Average Results from Five Samples over the Eight-week Test
Oil analysis has been the primary tool to detect incipient lubricant failure for the last half-century. The first step in determining an appropriate test slate for turbine oil is understanding its mode of failure. The authors were part of a research project that concluded in 2005, during which five turbine oils were circulated in immersion heated baths at 120 degrees Celsius for eight weeks. A wide range of analytical tests were performed in order to better understand which specific testing methodologies would provide the highest value for detecting early signs of turbine oil degradation and the associated by-products which negatively impact lubrication systems. Figures 5 and 6 represent a summary of results averaged from all five samples over the eight-week test.
The traditional testing methodologies for monitoring the oxidative health of used turbine oils are viscosity, acid number and RPVOT. It is clear from this research that these tests do little to reveal early turbine oil degradation and nothing to identify the fluid’s deposit tendencies. Here are a few of the more significant discoveries:
Figure 6. Data of the Average Results from Five Samples over the Eight-week Test
What about RPVOT?
The RPVOT test became an ASTM standard in the mid-1960s and has enjoyed several decades of high-profile use in helping end-users determine the remaining useful life of turbine oils. There has been a rising concern within the oil analysis industry, however, about using RPVOT on modern lubricant formulations that utilize complex antioxidant systems. The precision of the test in practice varies considerably compared to the precision statement in the ASTM standard. ASTM D2272 calls for a repeatability of 12 percent and a reproducibility of 22 percent for oils with values less than 1,000 minutes. Practically speaking, the repeatability and reproducibility of the test is generally accepted to be somewhere between 30 and 50 percent. A recently conducted mini-robin at an international standards institute reported 39 percent reproducibility. The recognized poor repeatability and reproducibility of the RPVOT test has made it much more difficult for data analysts to interpret.
Is there a place for RPVOT testing in today’s turbine oil formulations? Our view is that there may be some value in performing RPVOT tests on turbine oils, depending upon the objective and situation. For example:
These factors should be considered in the interpretation of RPVOT results.
Bill Parks, “Gas Turbines for Power Generation: A U.S. DOE Perspective”; www.eere.energy.gov. June 1, 2000.
Akira Sasaki, Shinji Uchiyama and Mariko Kawasaki, “Varnish Formation in Gas Turbine Oil Systems”, Journal of ASTM International, Vol. 4, No. 1, Paper JAI101419; presented at the ASTM Symposium on Oxidation and Testing of Turbine Oils in Norfolk, Va., on December 5, 2005.
Private conversation with Vince Gatto and William Marle (recently retired) of Albemarle Corporation regarding their research.
Greg Livingstone, Brian Thompson and Mark Okazaki, “Physical, Performance, and Chemical Changes in Turbine Oils from Oxidation”, Journal of ASTM International, Vol. 4, No. 1, Paper JAI100465; presented at the ASTM Symposium on Oxidation and Testing of Turbine Oils in Norfolk, Va., on December 5, 2005.
Greg Livingstone is Chief Innovation Officer for Fluitec. He has three decades of industrial lubrication experience focused on how lubricants degrade and to mitigate the risks associated with oi...
