How to Equip Lube Techs with Tools for Success
Are you a lubrication technician (lube tech), oiler or lubricator? Are you responsible for performing lubrication tasks for your company, such as topping up machines with oil, regreasing bearings or even determining if a machine might have a potential health issue?
If so, you have a direct influence on how lubricated machines are maintained. But are you equipped with the right tools and skills to perform this job effectively? World-class lubrication programs have a wide range of tools readily available from oil sample bottles to cleaning wipes
Essentials for Machine/Lubricant Inspections
One of the most important jobs for any lube tech is making smart inspections, and specific tools will be required for this task to be done correctly. A quality flashlight is a simple but essential tool that can be used to inspect the lubricant through a sight glass, level gauge or bottom sediment and water (BS&W) bowl.
A strong flashlight not only will enable you to verify the oil level but also to visually analyze the fluid for solid contamination, wear debris, water, color change or other unusual signs.
The design of the sight glass plays a role as well. The best option is a protruding (3-D) design that allows the flashlight to illuminate from one side of the glass to the other. It is also crucial that the flashlight shine through without a significant amount of refracted light.
Various types of flashlights and optical viewing aids may be able to provide other advantages for machine and lubricant inspections. These include a blue-light LED flashlight, a laser pointer, a borescope, a quality camera with a flash, an oil color gauge, pipettes, a telescoping magnet, a telescoping mirror and a spatula to inspect grease consistency.
Being able to view the oil in a machine through a sight glass is necessary because it’s not practical to take frequent oil samples in most cases. When a sample is collected, it is imperative to examine the oil in the bottle to quickly determine if any action should be taken.
Of course, there are many ways to inspect an oil sample other than through a visual inspection. Measuring the temperature of the machinery can be very useful in indicating potential issues. If a machine does not already have an oil temperature monitor, a simple temperature gun or thermal camera can provide a quick reading. This should be part of the machine’s inspection route, especially for critical assets or those with a history of overheating.
Effective Oil Sampling and Quick Oil Analysis
Taking a representative oil sample requires specific sampling hardware and tools, including a vacuum sampler, plastic tubing, certified clean bottles, sample bottle labels, a sample probe adapter, zip-lock bags, a lint-free cloth and a written procedure.
Once the sample is obtained, a quick visual inspection of the lubricant should be performed by the lube tech. Shining a strong laser through the oil will illuminate small particles and any evidence of entrained air or emulsified water.
After the initial visual inspection, the oil sample should be kept still for an hour or more. Another visual inspection can then be made to shed light on any water separation or particle accumulation at the bottom. A magnet may also be utilized to determine if the particles are ferrous in nature, which likely would indicate wear debris.
While oil samples will need to be sent to a well-equipped laboratory, it is beneficial to have certain types of instruments onsite for quick oil analysis. The most common onsite instruments are a patch test kit with a comparator, a viscometer, a particle counter, a hot plate with a dimmer switch, a magnet for quick ferrous-density inspection, a Schiff’s reagent test, a laser light for debris inspection, acid and base number test kits, and portable water testers.
Contamination Control and Lubricant Application Tools
A well-designed lube room will incorporate special tools for promoting contamination control even before the oil reaches the machine. These include sealable and refillable top-up containers, grease guns dedicated to a single lubricant, cleaning supplies, posted procedures for all lubrication tasks, and identification labels for all devices in contact with oil.
A filter cart is another valuable tool for contamination control. It can be used in a number of ways, which are detailed below.
Filter Cart Applications
Power Flush — This involves reducing the oil level in the tank or sump and flowing oil at a high velocity across the bottom to push out low-lying sediment.
Wand Flush — A wand is attached to one of the cart hoses and is used first to discharge at high pressure (kicking up adherent debris). Then the flow is reversed, and the wand vacuums the sediment.
Transfer Cart — Oil is transferred from a storage container (tote, drum, etc.) to the machine’s lube compartment.
Cleaning Stored Lubes — In this application, the cart multipasses fluid out of and back into the drum or tote to draw down contamination.
System Drain — Sump and reservoir drains will wash out debris better if the waste oil is pumped out as opposed to simply flowing out by gravity.
Line Flush — Remote lines and components often need to be partitioned to enable flushing. This can be done easily with a filter cart.
Hose Cleaning — Before new hoses are installed on a machine, they can be flushed of debris using a filter cart.
Off-line Filtration — Filter carts can be mounted permanently to a machine to supplement filtration.
Repairs and Equipment Rebuild Flushing — After machines are serviced, they need to be flushed thoroughly before they are returned to service.
Flushing During Equipment Commissioning — New machines have original fabrication debris and dirt that have ingressed during transport and storage.
68% of lubrication technicians do not have the necessary tools to perform their jobs effectively, according to a recent survey at MachineryLubrication.com
Cleaning Products
In addition to having the right lubrication techniques, maintaining a clean working environment is crucial for ensuring the effectiveness of lubrication and prolonging equipment life. Cleaning supplies play a vital role in removing dirt, grease, and other contaminants from surfaces before lubrication. Products like SCRUBS® Hand Cleaner Towels are specifically designed to clean hands, tools, and equipment quickly and efficiently, reducing the risk of contamination and ensuring that lubricants can perform optimally.
Scrubs® Hand Cleaner Towels
 Another valuable addition to your cleaning arsenal is the SCRUBS® Stainless Steel Cleaner Towels. These towels are specially designed to clean and polish stainless steel surfaces, leaving them free of grease, oil, and grime. By keeping high-quality cleaning supplies on hand, you can maintain the cleanliness of lube points and effectively reduce contamination, contributing to more reliable equipment.
Safety Equipment and Training
Safety equipment could be considered a lube tech’s most important tools. The standard personal protection equipment includes earplugs, safety glasses, hard hats, steel-toe boots and special clothing to protect against potential hazards. Depending on the job, other safety items may be necessary, such as gloves, breathing masks, etc.
Safety training is another common requirement for any plant activity including lubrication. However, for lube techs, the training should go beyond just safety. Machine maintenance, whether it is proactive, predictive or preventive, can be complicated. Lubrication training should be obtained and based on the tasks that will be performed.
This type of training often results in beneficial certifications, such as the Machine Lubrication Technician (MLT) and Machine Lubricant Analyst (MLA) certifications from the International Council for Machinery Lubrication (ICML).
Machinery Lubrication Reference Guide
Packed with useful checklists, look-up tables, charts and illustrations, the Machinery Lubrication Reference Guide is designed to make information easily accessible where you need it – in the field, on your desk or in your pocket. Lube techs can use it as a handy on-the-job reference or as a study aid for certification exams. For more information, visit the Noria Bookstore at store.noria.com.
