The reliability of turbines is pivotal to the success of power generation facilities — a problem with the main turbine can cause outages and production delays. A study performed by General Electric revealed that about 20 percent of forced outages in power plants could be attributed to turbines, and 19 percent of these issues were connected to the lubricating oil system.
Because the continued operation of turbines relies on the performance of turbine oil, it is important to select the right turbine oils and monitor them closely for signs of degradation.
This whitepaper can help you better understand how to choose a turbine oil to fit your needs, goals, and application as well as how to care for that turbine oil from storage to service.
Topics Covered in This Whitepaper
- Sludge and Varnish
- Turbine Oil Degradation Methods
- Thermal and Compressive Degradation
- Electrostatic Discharge
- Essential Turbine Oil Properties
- Evaluating Turbine Oil Performance
- Viscosity Testing
- Oxidation Testing
- Testing for Water
- Acid Number Testing
- Turbine Oil Cleanliness: Sampling and Levels
- Responding to Contamination
Educational material presented by Noria Corporation and sponsored by Shell Lubricants. Visit the Shell Turbo page for more information.
