Bel-Ray Releases New Open Gear and Rope Lubricant
Bel-Ray recently released a new lubricant for mining applications. Molylube Open Gear and Rope Lubricant can be used in general industrial open gears, pins, bushings, chains, wire ropes, cables, drive chains and sliding surfaces. The aerosol spray lubricant is designed to adhere to gear teeth and resist throw-off and slinging.
The unique formulation provides lubrication under extreme-pressure conditions while also offering water resistance and anti-wear, rust and corrosion protection associated with demanding mining and heavy industry equipment applications.
"Bel-Ray's Molylube SF100 is the leader in open gear lubrication for the world's largest and most demanding mining equipment," said Bret Jenkins, director of mining sales. "Now, the same protection is available in a convenient aerosol version, virtually eliminating wear in open gears in draglines, shovels, cranes and stationary rotary equipment."
Bel-Ray also recently introduced a new offering in its line of food-grade lubricants with the No-Tox Ultra F Oils. These mineral-based oils are NSF H1 registered for use where incidental food contact may occur, as well as compliant with current good manufacturing practices (CGMP), halal certified, and kosher and pareve approved.
Formulated to meet the needs of the food and beverage industry, the oils are intended to provide anti-wear, rust and corrosion protection in a wide range of applications, including hydraulic systems, gear cases, chains, compressors, bearings and circulating systems.
The No-Tox Ultra F Oils are available in the following viscosity grades: 32, 46, 68, 100, 220 and 460.
For more information, visit www.belray.com.
